Is there a forscan spreadsheet for expeditions somewhere?
zablalbaz
Raleigh
Hey All,
I have used forscan before and have everything needed. But I have only ever used it on my F150. I used the tutorial and spreadsheets over at the F150 forum. Have any of you used forscan on your expeditions to read/clear dts errors, or add features or enable Bambi mode lights? If so, do the same addresses and value changes work for the Expeditions?
JimR_TN
Middle TN
I would love spreadsheets for our Expys, however I haven't been able to find them either.
Mine is a 2007 which means limited settings available to change. I did turn off the TPS sensors as mine didn't work and I wasn't interested in fixing them. No more TPS warning light! I followed other examples, however I had to make a guess because it wasn't exactly like the examples I had found.
Super Moderator
Super Moderator
There is an older sheet. There is also a pinned thread regarding the 2015+ and FORSCAN settings. Expeditions are the red headed step child for modules and NO other Ford(Even the F150's) has the same combo of modules. Example, in the 2015-2017's the BCM holds a lot of the code, that in the 150/250 are in other modules. Read the 2015+ thread, and it will help, but to sum it up, for most I suggest they stay in the drop down options. That is 95% of what most people are looking to change(Honk when exit, Highs with Lows/Fogs, LED Markers, etc...). The 2015+, and 2018+ see way more options. Since I didn't own an Expedition before 2015 I have only played with a few earlier 3rd gens, and man they are even more of a hybrid module config.
JAMADOR
Spring, TX
^ Sounds like our 2013 Flex.
Strictly used the quick change drop-downs. Didn't want to risk being the Guinea pig on code changes.
Still haven't gotten around to seeing what's available on our Max.
Super Moderator
Super Moderator
Yeah, the flex is actually very similar to the Expedition in module layout, but coding is closer to the Explorer/Edge in coding based on what I have seen.
Super Moderator
Super Moderator
Sorry LokiWolf. I wasn't sure where to post this one. You can shut it down if you like and I'll post over in the forscan area.
All good, @Yupster Dog will move it when he sees it!
So we don't lose what has been said! Check those threads out in the FORSCAN area, and they should help. Tag me in them if you have a direct question. I did a fair amount of leg work for the 2015+ 3rd Gens with the FORSCAN engineers to get them supported and added.
Z
zablalbaz
Raleigh
Great TY. I'm not looking to do anything super weird. Just the usual stuff everyone else does I expect.
Super Moderator
Super Moderator
Then you should find them in the drop down options for the BCM and APIM most likely and should be able to do them.
mlself
