Boosted
I recently purchased a 2020 Expedition Limited and noticed the auto stop start wasn’t working. When I cycled through the menus in the dash I could see that it would tell me that Auto stop start was not functioning due to vehicle charging.
I ran a quick battery test and the state of charge was around 40% even though voltage was fine. The truck has no problem starting or anything else.
I purchased a H7 AGM battery from Walmart for $180 and put it in. Then I reset the Battery Management System by performing the following procedure.
BMS Reset Procedure:
Push start button once, but don’t start.
Flash high beams 5 times
Press brake pedal 3 times
Watch battery light on dash and wait for it to flash
Start vehicle and the system should be reset.
