Replaced battery and reset BMS
Boosted
North Jersey
I recently purchased a 2020 Expedition Limited and noticed the auto stop start wasn’t working. When I cycled through the menus in the dash I could see that it would tell me that Auto stop start was not functioning due to vehicle charging.
I ran a quick battery test and the state of charge was around 40% even though voltage was fine. The truck has no problem starting or anything else.
I purchased a H7 AGM battery from Walmart for $180 and put it in. Then I reset the Battery Management System by performing the following procedure.
BMS Reset Procedure:
Push start button once, but don’t start.
Flash high beams 5 times
Press brake pedal 3 times
Watch battery light on dash and wait for it to flash
Start vehicle and the system should be reset.
HazBeen
Great Lakes
Expedition Workshop Manual sections regarding Charging System operation and Battery Load Shed events are attached below...
  • Charging System - System Operation and Component Description - 2020 Expedition Workshop Manual.pdf
  • Battery Load Shed - Description and Operation - 2020 Expedition Workshop Manual.pdf
Danm355
Rochester, NY
That works great. I had to do that on my wife's 2020 escape when we replaced the battery.
