Aftermarket sub installed in stock box
billyfrancis40
canton
Well I decided to upgrade my factory 8 in subwoofer and I’m not impressed I used a skar 8 inch not sure of the model but it’s the lowest power one they got like 150 rms 4 ohms dvc . It didn’t fit exactly I took the cover off the stock one and adhesed it together with strong stuff bolted it up in the box and looked well. I filled in the rear hole with epoxy as well and then put black atv where the cords came in the front to help seal it better. Let me tell you getting the trim and box out was a ****. Looks factory when installed back up but sounds about the same as stock didn’t expect much. Needs a better box and more power for sure can I use a amp and wire it to the stock wires back there by chance if anyone knows thanks
thegerb50
