2022 Expedition Power Windows
ITGuy80
maine
Hey everyone, I have a new 2022 Expedition. Recently the drivers side power window buttons (front only) and power mirrors adjustments stopped working. The other window controls seem fine and the rear window buttons work from the drivers side.
I’ve only had the vehicle a month, about 1100 miles. Before I make an appointment and lose my vehicle for a day, anyone have some things to check prior to taking it in?
fothco
BC
We have a 2022 Expedition-Max - Ltd . Such odd issues seem to correct themselves . Shutting down , waiting for awhile etc . The serious issues come when the battery runs down fully . Then , deep computor problems arise .
nationalgallery
I've had mine for 3 1/2 months; a couple times the one-touch close for the driver's window wouldn't work — I'd have to hold the button until the window completely rolled up. Looked in the manual and it shows a little sequence to follow (on p. 124) and then it starts working again. Go figure....
s1000pre
minneapolis
Same here, 2022 XLT Max, issues with the one touch passenger side. Held it in position until closed. Happened twice about a month ago. Hasn’t happened since.
GGecko311
South East
Mine did this exact thing this morning, couldn't roll down front windows, nor adjust the mirrors but the rear windows would still roll down. 2 hours later everything started magically working again.
iDowza
I began having this issue today as well!
Front window controls and mirror controls from the driver do nothing. Rears still work. The front passenger window control works. From their door. Hopefully this fixes itself as others have stated.
Anyone else with this issue?
fkrabach
Dearborn, MI
I have had this happen twice now. The first time I assumed it was just frozen. It was just over 50 this morning when it happened so it wasnt frozen. What I discovered was 3 DTC's with the main one being in the Driver Door Module: B1087:87; LIN bus A Missing. After reviewing the fault history I was able to see a pattern that related to using the remote start via the Ford Pass app. I dont know why that would affect the LIN bus. Especially after 2 or 3 power cycles; shut car off, open and close door, wait for everything to shut down, then restart. I will keep looking into this and update if I come up with more definitive information. If you have any additional details that may relate to it, please share as it may help us narrow it down.
1775SS
Clarence, NY
I've had the "one touch closing" stop working twice so far. Easy fix. Also had a complete failure with the driver door module. I just shut the car off, waited about 30min. everything came back.
I said it before and I'll say it again,
the only reasonable explanation for any unexplained issues, mechanical or electrical is.........
In the words of Sting,
There are " Ghosts in the Machine "
