2022 High-beam Adjustment
rd618
new york
Hi all, had an issue with driver side low beam headlight on my 2022 (reflector style LED), ford replaced it under warranty.
Issue now is the high beam is aimed way too low. Low beam is fine and set correctly.
I’d like to adjust the high beam myself instead of another trip to the dealer.
Any suggestions on where the high beam adjustment might be found? I can’t find a schematic that shows it.
The low beam is easy that’s a Phillips screw, but it doesn’t move the high beam.
I couldn’t easily see an adjustment point for the two high beam reflectors.
