2003 Expy Timing Chain Done
Hamfisted
Ft Lauderdale
Guests in town for Thanksgiving and looking for something to do. So we ripped into the Expy for a quick timing chain and oil pump replacement job. The Expy has 211k miles on the clock, and always been fed Mobil One 10w-30 oil, with regular changes at 7000 miles and used only Motorcraft filters. Its the older 2V motor, so the strain on the chains is a little less than the 3V motors. Started to develop a cold start chain chatter about 10k miles ago, but nothing bad. Just a little chain slap for the first few seconds until oil pressure built up. After disassembly we saw no blown out tensioners or busted guides. Only a little slack in the two chains due to wear. The tensioner guides showed only about 1/16 track wear from the chains right where the hydraulic tensioners push from behind. Otherwise they were fine.
There is about 4 hours of tear-down just to get to the chains. We didn't remove the heater hoses and coolant, just the passenger side fenderwell liner and tire to get to the lower valve cover bolts on the passenger side. In retrospect it would've been easier to drain the coolant and remove the heater hoses. We used Fel Pro gaskets on reassembly. That DAP super glue from HD works very well to keep the valve cover gaskets in place for reassembly. Otherwise those gaskets like to fall out of their grooves and out of place. Didn't want any oil leaks afterwards. The flex head ratchets/wrenches and electric impact drivers were life savers too. We did this job just for piece of mind. Not experiencing any engine performance issues or noises other than the cold start chain chatter. Probably could've gone at least another 50k miles on these parts without issue.
Plastic hydraulic tensioners .... ugh .... weak spring inside. You can compress 'em by hand... but at least the seals weren't blown out yet ....
Overall the job really took a full day. We took several breaks just to keep from throwing things. The installation of the chains is very straight forward, as the chains are color marked to make timing easy. For the oil pump installation we didn't remove the oil pan, but if I was doing it by myself I would have on this 2wd Expy. A 4wd I would probably not. But getting the bolts back into the oil pickup line / to pump was a huge PITA, I don't care what FordTech says.
After re-assembly was complete we left the crank sensor unplugged and cranked the engine until oil pressure showed up on the gauges then plugged the sensor back in and she fired right up. Accidentally left #4 fuel injector unplugged, but once we sorted that out she purrs like brand new again.
Very nice breakdown, I’ll be doing the timing job on my 5.4 3V in spring. The 2V is nice in that it’s a color coded system. Mine also has the startup rattle, so far no dieseling sounds or codes....hoping to make it to warm weather.
Hamfisted
Hamfisted
Ft Lauderdale
Well you can help your engine out using something heavier than that 5w-20 oil that's for sure. The timing sets are the same if you use Melling. I used the cast iron hydraulic tensioners with the grenade pins and ratcheting mechanism, rather than plastics. The chains are color marked to make the timing setup easy.
If you attempt this job it would really be helpful to have an assistant or two, and better if they have experience tearing down the 5.4 motors. A set of metric Gearwrench flex head wrenches is a must have and a 1/4" electric ratchet like the Milwaukee extended reach M12 ratchet will make the job so much easier. A 36mm open wrench for the fan. A 32mm deep well 6pt axle socket to turn the crankshaft (AutoZone). That special crankshaft tool to set the crank at TDC is a nice to have tool, but if you have the 32mm socket for turning the crank you can set it with the timing mark at 6 O'clock too. It's not a fun job. Down here in FL they get about $3k for this job.
OTC 0624 Crankshaft tool on Amazon ....
https://www.amazon.com/OTC-6024-Crankshaft-Positioning-Tool/dp/B000F5ECRM
Permatex Oil Resistant Silicone....
https://www.amazon.com/Permatex-821...motive&sprefix=Permatex,automotive,185&sr=1-1
Milwaukee 1/4" Extended Reach Ratchet....
https://www.amazon.com/Milwaukee-Fu...=Milwaukee+1/4+extended,automotive,187&sr=8-2
Gearwrench Flex Head wrench set on Amazon....
https://www.amazon.com/dp/B0002U2ODE/ref=emc_b_5_t
Gearwrench Flex Head ratchet set on Amazon...
https://www.amazon.com/GearWrench-8...8HCRB1WCVWA&psc=1&refRID=E8DRR8RRM8HCRB1WCVWA
Sunex 6pt Impact socket set on Amazon....
https://www.amazon.com/dp/B00JO1BO1K/ref=psdc_553372_t3_B078KFWYKT
riphip
Memphis, TN.
Good to see you kept your guests entertained. Great job! Hopefully will be a long while before mine needs this. Running Rotella T6 5-40w since I purchased. Great teamwork!!
dlyoung1
Central Texas
Glad to see yours went smoothly. I just finished the install of a timing set on my wife's '03 4.6L 2V, and I am having issues. Everything is back together, I replaced the crank and cam position sensors and plugged everything back up. Idles with just a hint of a stumble or a miss somewhere. I put the code reader on it and was very surprised to see codes for injectors 3 AND 4 AND 5 circuits open!
Of course, I have checked harness plugs on all cylinders and all seem solid. Anyone have an idea? Thanks!
Hamfisted
Hamfisted
Ft Lauderdale
How many miles are on the Expy? What kind of wear did you find ?
What were the DTC codes exactly ? My issue after I buttoned everything up was that I forgot to plug in injector #4 . But once I plugged that back in everything was fine, no codes. If you have an AutoZone nearby they rent the noid light test kit to test the fuel injector signals.
https://troubleshootmyvehicle.com/ford/4.6L-5.4L/how-to-use-a-noid-light-1
https://www.amazon.com/gp/product/B...gn-20&linkId=d4f33b9fabf2d1dc035d8bc834022fca
Hamfisted
Hamfisted
Ft Lauderdale
Vincent Vega
Huntington Beach, CA
https://www.amazon.com/Permatex-82180-Maximum-Resistance-Silicone/dp/B0002UEN1U/ref=sr_1_1?crid=2IZ5CD6B6NLXA&keywords=permatex+ultra+black&qid=1575469026&s=automotive&sprefix=Permatex,automotive,185&sr=1-1
https://www.amazon.com/Milwaukee-Fuel-Extended-Ratchet-Bare/dp/B07YKWZ9V3/ref=sr_1_2?crid=20CQSZW4F2H9R&keywords=milwaukee+1/4+extended+ratchet&qid=1575469112&sprefix=Milwaukee+1/4+extended,automotive,187&sr=8-2
Hamfisted, I have the cold-start chain rattle and am getting ready to do the timing surgery. What brand oil pump did you install, and did you replace the roller followers? Any thoughts on that.
Hamfisted
Hamfisted
Ft Lauderdale
Vincent I used the Melling high volume pump from Rock Auto. I didn't replace the rocker arms at the time when I did the timing chains, but I did when I did the head gaskets this past December. Not that they were bad but just as cheap insurance after 225k miles and I had the cams out anyway. I used the Ford OEM rocker arms from my local dealer. I probably had the beginnings of a head gasket leak back when I did the timing chains, but didn't realize it, or I would've yanked the heads off at that time. The motor never overheated, it just started blowing coolant out of the reservoir after a long drive. I nursed it along for six months before I actually did the repair and had the heads rebuilt at the same time.
This socket works on the Ford Triton crankshaft for turning it without damage >
Ford Triton Crankshaft Socket on Amazon
Dmcritt22
