2016 XLT drivers door power lock not working
HawaiiFiveOh
Baltimore Md
The wife is having an issue with the drivers door not unlocking with the fob. After checking a little bit, it does work with the door fully open. I’m thinking a broken wire in the door/boot to the cab. Has anyone had this happen? Just curious what color wires I’m looking for or anything to look out for, I haven’t started to dig into it at all. Thanks
THRFTY
YES! I have a 2015 with the same issue. I just replaced the driver door lock actuator/latch thinking that was the issue, but it remains. The driver door will lock/unlock with the inside switch, and with the fob when the door is open, but not when the door is closed, so I either can't lock an unlocked door with the fob, nor can I unlock a locked door with the fob. HELP!
My work around for now--either use the P-Key (in the fob) to mechanically unlock a locked driver door OR lock the door from the inside prior to exiting.
I wasted the time to replace the latch, but I learned about it from taking the door trim off and getting inside the door. the wire harnesses for all the switches are not very long. I can see these being abused when servicing the door, and wonder if the wires were inadvertently damaged in prior door servicing and perhaped aged enough in a slightly damaged state to cause an open circuit somewhere. I'm pretty baffled otherwise.
