$550 to replace rear brake pads: reasonable?
HazBeen
Great Lakes
2018-2021 Electronic Parking Brake (EPB) Service Mode Activation and Deactivation​
Activation
WARNING: Service actions on vehicles equipped with electronic parking brakes may cause unexpected parking brake application, which could result in injury to hands or fingers. Put the electronic parking brake system into service mode prior to servicing or removing rear brake components. Failure to follow this instruction may result in serious personal injury.
NOTE:
EPB service mode is also known as EPB maintenance mode.
NOTE: Carry out the following service mode activation procedure to deactivate the EPB system. The EPB system can also be deactivated using the diagnostic scan tool and following the on-screen instructions.
  1. Set the ignition to ON.
  2. Press and hold the accelerator pedal and place the EPB switch to the RELEASE (downward) position. Continue to hold the accelerator pedal and EPB .
  3. Set the ignition to OFF then set the ignition to ON within 5 seconds. Continue to hold the accelerator pedal and the EPB switch.
  4. NOTE: The EPB system will be deactivated, preventing parking brake application until service has been completed and service (maintenance) mode has been deactivated. The yellow EPB indicator will be illuminated and Maintenance Mode will display on the message center.
    NOTE: When replacing rear brake pads in service (maintenance) mode, the brake caliper piston must be compressed into the caliper housing. The brake caliper piston does not have to be rotated while compressing the piston.
    Set the ignition to OFF then release the accelerator pedal and EPB switch.
Deactivation
NOTE:
Carry out the following service mode deactivation procedure to activate the EPB system. The EPB system can also be activated using the diagnostic scan tool and following the on-screen instructions.
  2. Press and hold the accelerator pedal and place the EPB switch in the APPLY (upward) position. Continue to hold the accelerator pedal and the EPB switch.
  4. NOTE: The EPB system will fully apply and release the parking brake to guarantee sufficient air gap between the rear brake pads and brake disc.
    Release the accelerator pedal and the EPB switch.
© Copyright 2023, Ford Motor Company.
2022-2024 Brake Service Mode Activation and Deactivation​
Activation
WARNING: Service actions on vehicles equipped with electronic brake booster without activating the brake system service mode may result in unexpected hydraulic brake application or a false leak detection DTC. This will significantly reduce the performance of the brake system. Failure to follow this instruction may result in serious personal injury.
NOTE:
Brake service mode is also known as brake maintenance mode.
NOTE: Prior to carrying out the brake service mode activation steps below, clear all EPB and EBB related DTCs.
NOTE: Carry out the following service mode activation procedure to deactivate the EPB and EBB systems.
NOTE: This mode is required to deactivate the brake boost and allow the entire brake system to bleed manually.
NOTE: This mode will cause all the associated brake warning indicators and text messages to appear.
  2. Press the brake pedal and release the EPB .
  3. Release the brake pedal.
  4. Press and hold the accelerator pedal and place the EPB switch to the RELEASE (downward) position. Continue to hold the accelerator pedal and EPB switch.
  5. Set the ignition to OFF then set the ignition to ON within 5 seconds. Continue to hold the accelerator pedal and the EPB switch.
  6. Set the ignition to OFF then release the accelerator pedal and EPB switch.
    • NOTE: The brake system will be deactivated, preventing brake application until service has been completed and service mode has been deactivated. The yellow EPB indicator will be illuminated and Maintenance Mode will display on the message center.
    • NOTE: When replacing brake pads in service mode, the brake caliper piston must be compressed into the caliper housing. The brake caliper piston does not have to be rotated while compressing the piston.
Deactivation
NOTICE: The brake system performance will be significantly reduced when the brake system is put in service mode.
NOTE:
Carry out the following Brake Maintenance Mode deactivation procedure to activate the EBB and EPB systems.
  2. Press and hold the accelerator pedal.
  3. Place the EPB switch in the apply (upward) position. Continue to hold the accelerator pedal and the EPB switch.
  4. Firmly press the brake pedal for at least 1 second. Release the brake pedal while continuing to hold the accelerator pedal and the EPB switch.
  5. Set the ignition to OFF then set the ignition to ON within 5 seconds, then release the accelerator pedal and the EPB switch.
    • NOTE: Once the ignition is set to ON, the EPB system will immediately apply and release the parking brake to guarantee sufficient air gap between the rear brake pads and brake disc. If the EPB switch is not released prior to completion of this sequence, it will apply the EPB . The EPB will have to released prior to moving the vehicle.
    • NOTE: When Brake Maintenance Mode is deactivated, the Yellow Parking Brake and Red Brake Warning Indicators turn off and "Brake Maintenance Mode" no longer displays in the message center.
  • Electronic Parking Brake (EPB) Service Mode Activation and Deactivation - 2018-2021 Expedition...pdf
  • Brake Service Mode Activation and Deactivation - General Procedures - 2022-2024 Expedition Wor...pdf
