Check charging station
Vinmiz75
Chesterfield Virginia
Hello, I have an 04 expedition Eddie Bauer 5.4 v8. My check charging station keeps coming on. My battery is good, and the alternator has been replaced twice in 2 months. I was told it could be the PCM.
Hamfisted
Ft Lauderdale
This issue has been covered dozens of times. Generally it's caused by installing the wrong amperage alternator or just a poor quality rebuilt alternators from the discount parts stores.
What is the amp rating and brand of alternators you've been installing? Unless you have FACTORY navigation option, it should be a 110 amp alternator. Anything else will trigger an error from the PCM and you'll get the message on your instrument cluster.
DJ04
Miami, OK
Factory Navigation system has been mentioned numerous times. With that system is a 135 AMP alternator needed? The Ford Parts online system calls out a 110 AMP unit. What's going on? I am confused. 2004 Expe, Eddie Bauer, 5.4 L 4x4 with Factory Nav, fancy radio with 6 CD changer.
Yupster Dog
Super Moderator
Super Moderator
For a member to get an alert you must quote them as i have you
or you can mention them by putting the "@" symbol in front of their name
@Hamfisted
DJ04
Miami, OK
I am confused. The online FORD parts lookup has a 110 amp alternator for my Expy which is an '04 Eddie Bauer with everything on it (I did not buy it new) including the Factory Navigation System. I have read on this forum abut 135 amp alternators being the right ones and that does not match the online Ford call.
