Dealer Fluid Service
dcsang
My local dealer refuses to change transmission, F/R axle, and transfer case fluids because the vehicle is at 100K and the maintenance schedule specifies 150K. Is this typical? I am not the original owner and thought it might be prudent to perform these services.
I am also hearing and feeling a light clunk in the front-end when in A4WD and releasing the gas pedal. I can make repeat that occurrence most times by pressing and releasing the gas pedal while the vehicle is in forward motion. It was suggested that I change the transfer case fluid to see if that might resolve teh issue.
99WhiteC5Coupe
I’d find another dealer.......
Trainmaster
Old School Member
Rockaway Beach, NY
What year truck is this? Find a dealer who will do the work you pay him to do. And hold on to your wallet. The dealers in your parts get a lot of money for this work.
D
dcsang
It's a 2013 Limited. I'll call another dealer in Brooklyn but I expect more of the same. I expect the transmission fluid change to be costly, though the dealer wouldn't even provide an estimate. If any locals have a service location recommendation please chime in. I don't mind heading to Eastern LI as long as the service is performed properly.
Trainmaster
Old School Member
Rockaway Beach, NY
I'm in Rockaway and unfortunately I'm stuck doing my own work because I haven't found anyone who does the right thing. If you do find someone, let me know. A dealer in Hempstead replaced a transmission bulkhead connector under warranty and overfilled my transmission by two quarts.
D
dcsang
Thanks for the warning. That kind of service is exactly what I am worried about. I don't get the sense of comfort from speaking with some of these service departments and it's quite disappointing considering the costs associated with dealer maintenance.
I'll share any positive findings as I continue this quest.
chadh032267
Lafayette, La
I have a 2013 also and i have no problems at all with my Transmission except that fact that it has 88K miles. Yes the manual says 150K service interval for Transmission Fluid/Filter flush and change. The dealerships in my area charge 205- 280 to do this service. Surprisingly the Lincoln dealer is the 205 charge and they have a better service dept than all the ford in my area of Louisiana. I am thinking of doing it myself because of the cost. You tube has many videos
Plati
I'm at 100K on my 2014EL.
It's runs perfect in every way.
I plan to do those 4 fluids now.
I don't think it's absolutely needed but I still want to do it. How could it cause a problem?
Dealer refuses to do it?
Dealer refuses service revenue?
Very strange.
If you could find a good independent shop, I would do it there vs Dealer anyway. The diffs are easy but Black said you may have red loctite to deal with and need a torch.
I would probably write that Dealer off my list, that's just me.
Gary Waugh
Princeton, TX
I have had my dealers replace all fluids at 60k miles (I do a lot of towing and it seems cheap insurance to me) none of them have ever questioned it, I think your dealer needs to rethink his position, I would suggest finding another dealer, there are no known issues to me to changing fluids early (except possibly wasting my money) but there could be many upsides!! I find even at 60k miles the gear changes become smoother and quicker after the fluid change, could be a placebo effect (my mind trying to justify the cost!, but I doubt it as I have done this 3 times and noticed the difference every time.. I would strongly recommend changing all the fluids if you don’t know the full history of your truck.
