Floor jack suggestions
Sclass-hole
Noblesville Indiana
I've been looking around and I think I've decided on a 3 ton. It should be enough right? I don't plan on jacking the whole truck up at one time so how much jack do I really need to raise one wheel at a time?
I appreciate any feedback. I don't know much about floor jacks but I know that the little 1 1/2 ton I have now won't work.
dougmcp
Roseville, CA
I use an old Harbor Freight 1 1/2 ton on mine and it struggles but still works.
You should be happy with the 3 ton model. Be sure to check that it goes high enough for your intended purpose.
Sclass-hole
Sclass-hole
Noblesville Indiana
walnuts4x4
Watertown, NY
I have a Kobalt 3 ton... with quick lift... basically one pump until it hits resistance... came with 2 jack stands too... have had it for 10 years and still going strong
98EXPY 5-0
PA
SCLASS - Is the 18" lift enough? I was looking at the 2 ton model because it lifts 23". My exped is stock height.
98EXPY 5-0
PA
I bought a 2.5 TON jack with 20" max height. I stuck it under the frame right in front of the rear tire and tried to jack it up. It tops out before the tire gets off the ground. So I guess 20" isn't enough.
sgtowing
Supporting Members
Valrico, Fl
If a jack doesn't go high enough, use some wood. Like a couple of 2x4 or a 4x4
Sent from my DROID BIONIC using Tapatalk
98EXPY 5-0
PA
I've always been weary about doing that. Would you put the wood on the ground under the jack, or on the pedestal? I've done it under the jack before, but with a smaller jack and a much smaller vehicle.
I'm going to be replacing the lower trailing arms and I'd like to get it fairly high to let the axle hang a bit.
the_plugger
