Folding mirror wire diagram ?
Roindhouse
Ga
Have an 06 limited with the power and heated mirrors and folding mirrors
The drivers mirror hasn’t folded in years , never been a problem for me .
the black plastic housing on the drivers side has been cracked for a while , and I recently snapped off the passenger mirror backing up and snagging it on a tree , so I bought a set of new aftermarket mirrors and installed them
The passenger one works fine and folds
The drivers side will adjust , but I need to get it to fold out , since the new mirrors came in the folded position .
Any idea which wire does that ?
Obviously it’s an issue in the wiring harness between the switch and the drivers mirror ,
If I knew which color wire it is , I can either jump it and fold it out and forget it , or find the bad connection and bypass it , or splice it to the passenger side fold wire .
Do all the function wires use 12 v ?
If so I can experiment on the broken one and figure it out ?
whtbronco
Winchester, VA
Can you have someone hit the switch and probe the connector to figure out each wire and the associated voltage? I don't have that wiring diagram, sorry.
R
Roindhouse
Ga
That’s the next step if I can’t find a diagram
Get a needle and backprobe the connector ,
It’s gotta be a bad connection or wire in the drivers door
Since the passenger side folds , the switch and the wire to the passenger side obviously function fine .
Hamfisted
Ft Lauderdale
I attached the wiring diagram to the circuit if that helps.
  • Expy Folding Mirrors.pdf
R
Roindhouse
Ga
Took a good look tracing wires and found a broken wire .
Snapped off at the connector , clipped it out of the connector on both ends and used a spade connector to get it working again.
