From 4'z to 6'z!!!
Which set of 26 inch rims should I get?
  • Total voters
    13
  • Poll closed .
Hampton, VA
Well I'm about to make that move from 24 inch rims...to 26 inch rims...the problem i have now is which one do i get? i've placed them in preference order...left to right...most favorable to least favorable...you may have to click on the pic and let the viewer make it bigger...
jacks3am
michigan
god fathers, but really any of the three that are not the tri spoke ones are sexi
KWT2000
NINE MILE FALLS
the vct wheels would be my choice... the trispoke they use to make those in the tuner market but problems with them cracking due to stress and thats with a 4cylinder import not an expy
Hampton, VA
the HELO's are soooooo different than the other tri/stars wheels thats you see out there right now...the Stada Denaro's arent getting justice in that pic...they go HARD!!! the only reason the 2 Crave is in 2nd place is because of the rivets...i prefer wheels with the rivets for the added depth the wheel gets...PLUS you get a true measure how deep the lip is...i've only seen 1 other person with 2 Crave...different wheel...but it is similar to other low end/cheaper wheels (style)...
WHOISMOOTOO
Dallas, TX
I'd say crave with a green insert, show off those brakes & rotors + hell of alot easier to clean
Hampton, VA
i forgot!!! the helo's will cover the caliper covers...
OK...#3 is OUT!!! no HELO 849...
:Bye:
Racenut
Deming, New Mexico
I was in a toss up between the Crave and the Godfather's, but I would go the Crave's clean looking and so much easier to keep that way plus they will show off your caliper covers really well!
Hampton, VA
but look at this....too clean...
tallsville
LA
id say 2 or 4.
how about this ones the greed duece if you really wanna show of your calipers and the hypnotic 360 and see if you can get green inserts but the cnote looks pretty good
check out hipnotics site you can customize the rim colors
http://www.hipnoticwheels.com/wheelcustomizer/
mlself
