Front left wheel humming
whtbronco
Winchester, VA
The power steering pump growling/whining sounds very different than a wheel bearing or tire to me. If it was the power steering pump it should be the same noise you'd hear when turn the steering wheel until the spindle hits the stop(lock to lock so to speak) It does make me wonder when was the last time the power steering fluid was changed. I go a bit overboard, okay a whole crap load overboard, I change the power steering fluid every year. It's only 1 quart, it's easy and it makes me feel better.
Drae
Anchorage AK
Are you guys jacking the vehicle up and checking top to bottom wobble? It's been times where it seems to be one side creating the noise but it's actually the other side. Might as well check the back also. If affordable it's always best to replace wheel hub assemblies in pairs because the other side may not be far behind on failure. Sometimes you have to throw money at these old vehicles to eliminate things especially if you're able to save some money and do it yourself. Check for play in the upper and lower control arm bushings also.
Yupster Dog
Super Moderator
Super Moderator
This ^
Also what is your time worth?
Second one will take half the time the first one did if you do it at the same time.
