Hellwig 7696 is installed on 2024 Expedition
Hellwig
It is a perfect replacement for the factory front sway bar. The hardest part is to lift and align the bar with six bolt stems. It is very heavy. I had to use several travel trailer stabilizer jack pads to lift one end of the bar, and then I held the other end myself to bolt it on.
Bracket bushing nuts: 15mm (46lbs.ft)
End link nuts: 18mm (59lbs.ft)
Stock transmission fiber cover nuts: 8mm (79lbs.INCH)
H
Hellwig
How is ride quality with the upgrade?
I do feel it provides more stability when I make turns on local roads. Someone said it gives a day/night difference, which I do not feel that much yet. I will test it on highway tomorrow. Honestly, I think the factory front bar is good enough for most owners. But the factory rear bar definitely needs to be replaced with Hellwig 7688. I do feel a lot difference with the rear bar replacement.
Deadman
Wisconsin
I agree the rear bar way far more noticeable because the rear is this vehicles downfall with its outdated IRS geometry. The rear bar stops the side to side head bobbing action.
The front bar makes it lay on the road and handle much better at speed and in corners.
If these sway bars didn't exist, I'd have sold my expedition the first few months I bought it new. Its pathetic how they come from the factory.
H
Hellwig
Update: I drove the vehicle on highway today. The front bar gives a firmer feeling when I switch lanes. At a local roundabout, I could pass it faster and I felt same level of control as I drove my 2014 RAM 1500 (Front: Double Wishbone Suspension; Rear: Live Axle with Tuftruck heave duty springs). Overall, I am satisfied with it. By the way, I do not know what theory is behind it or if I am wrong, but I do feel my steering wheel is a little firmer on either highway or local roads.
H
Hellwig
You remind me before the upgrades. Even a gust wind on highway made the vehicle sway, especially at the rear. And I was even not towing anything. My first towing experience was horrible because I didn't have those hellwig bars and rear Sumosprings support at that time. Whenever a semi truck passed me, it made me feel the 4200lbs travel trailer would collide with it (I-75 Tampa area).
JimmyM
Boston, MA
I've been looking at these Helwig bars for my '23. But I'm holding off until the '25 comes out. If it's a hybrid, I'm trading and the '25 will get the new bars. Otherwise, I wouldn't mind a little more roll stiffness. Don't get me wrong, my '23 feels damn good. But better is better
H
Hellwig
If the resigned model adapts to hybrid, I doubt the front bar could still fit. You would be the first to test it. lol
Shawnee OK
I replaced the rear only with the Helwig unit on my 2017 EL. It made a night and day difference. The front would also probably improve the handling but I detected that the rear by far needed the most help.
Adam J
different gen Expy, but i did Hellwig rear, then also front on my 2016 SSV - rear did more than the front, but they both help a lot - much flatter and more controlled handling. I found the front factory anti sway bar to be VERY substantial, not leaving a ton of room for improvements other than materials quality. The factory rear bar was thin and of a by far weaker materials than the Hellwig.
