When you turn off the car the alarm options pop up in the instrument cluster. You can disable the motion detector there. I think the option is called perimeter. The motion detectors will default to on the next time you start the car.
Mine doesn’t. You can select the option for it not to prompt on shut off and then you’ll never see the pop-up on shut off again...so you need to know how to get into the menu.
I didn't realize you could disable the prompt either... I see it every time i shut off the car and I am still inside...Mine doesn’t. You can select the option for it not to prompt and then you’ll never see the pop-up on shut off again...so you need to know how to get into the menu.
