In search of FORScan mods - 2021 Exp Limited
kingkase
I'm looking for the following changes on my 21 Exp Limited. Any help is appreciated.
-Disable Auto High Beams - I use the auto headlights feature, but I want to control high beams manually.
-Disable Handsfree Liftgate sensor - I want the liftgate buttons to work, I just want to disable the foot sensor so it quits hitting me in the head when working near the hitch. I have seen the physical mod where the antenna cable is disconnected, is this the best/only way?
thank you in advance,
KK
apex96
PA
You can disable auto high beams in the instrument cluster, it’s just a setting that can be unselected.
Best way to disable the foot activated lift gate is the physical modification.
K
kingkase
Thanks for the tip Apex! I found that setting about 5 layers deep in the menu. One issue solved.
I'll have to find a dry day during my holiday break to lay down under the bumper and perform the antenna removal.
K
kingkase
Today I found a decent afternoon to be under a vehicle.
I used the help of the post https://www.expeditionforum.com/threads/rear-hatch-operability.37909/page-2#post-328138
The antenna plugs into the receiver on the side. I was able to remove the antenna wire out of the back of the plug (remove the small purple clip on the plug) and then reinsert the plug to keep the receiver clean. Then I put a ziplock bag over the antenna wire and taped it up onto the receiver cover in case I should ever want to reverse this and restore operation.
I highly doubt it.
Pictures provided for those that follow a similar path.
KK
