Leak over drivers side rear window
JamaicaJoe
Oviedo FL
With a lot of rain I have a leak over drivers side rear window. It drips onto the panel below the window and originates from the plastic trim that overlaps the head liner. I thought I had this sealed by running sealer along the window. I also found water collecting on the trim at the base of the tail gate. Anyone have this problem. I cant duplicate with a hose.
Dobermans
CA
The only known leak issue that I know of is the windshield, which causes gem problems. Other than that I have no idea. Is your weatherstripping dried out?
JamaicaJoe
JamaicaJoe
Oviedo FL
The weatherstripping around the doors and rear hatch are fine. I am kind of wondering about that square air vent at top of the hatch that vents to the outside. The plastic trim is a bit loose.
