Liftgate Button Removal
Zerokoo149
Utah
I'm trying to figure out how to remove the liftgate button that is in the liftgate to replace it. The button pictured in this thread:
I don't to start prying at it since I don't want to mar the plastic around it. I imagine it's a fairly simple removal process, but I'm not sure if I have to pop off the whole panel and remove from the inside. Has anyone on here done this before and could tell me the best way?
I already checked other threads and youtube, but wasn't able to find anything.
Thanks in advance!
LegalBrief
zephyr Cove, NV and SFO
You take off rear panel with a soft plastic trim pry tool, then you can release the switch from the rear and or pop it out. Otherwise you will scratch
Z
Zerokoo149
Utah
Thanks for confirm, only took about 3 mins to pull the panel off.
Funny enough, I saw immediately that the switch was operating perfectly once I popped it out of the housing. As soon as I would put it back in, it would start sticking again. I just shaved a little plastic around the 4 sides of the opening with a utility knife, I had to do it a few times inserting and taking the button out. Finally after the 3rd or 4th "shave" it started working fine and hasn't stuck since.
Everything looks factory again once I reinstalled the button, in case anyone else runs into the same issue with the button sticking. Total job about 10 minutes and $0.
Michael D Morris
Florida
As the others have recommended, I used a soft plastic trim tool and the button popped right out. No need to remove any panels. A new button (switch) was about $28 at the Ford dealership.
5280tunage
colorado
I have a similar post on here where I detail part of the design flaw with these buttons. there is nothing mechanical that provides the return force for the button, other than a flimsy rubber filament. If these were maybe designed more like a keyboard key that has springs that return the key's to their resting position, it might last longer. In cold weather the rubber becomes stiff and functions even worse. I put a little silicone lubricant in mine the last time I took it apart, that also seemed to help a bit, but about a year later I'm feeling it stick again, especially as the days are getting colder, just a cheap flimsy design.
