No reverse locked in 4wd pleas help
jhughes76
Tennessee
I have 99 expedition xlt a4wd that is locked in 4x4, when you put in reverse it doesn’t move (acts like it wants to), drives in neutral but only one gear, drives normal in drive but with no overdrive. I’ve checked the shifter cable/linkage, transfer case motor and tried to check the vacuum to the front dif but apparently my car doesn’t haven’t it. Any help?
Fastcar
FL
You have done about all I would check with one other thing. I'd disconnect the battery for about 10 minutes. There is so much electronics in these trucks that can fail and bite you in the ass.
Don Hall
SANTA CRUZ, CA
Reply from another forum:
