Oil leak?
cozyjhoan
Arizona
Hello guys. I have a 04 Ford Expedition 5.4 and I am getting some sort of leak but i can't find the exact name of this part. It is located next to the oil pan and behind the oil pressure sensor as you can see. If any of you guys can help me out I would appreciate it. I will provide an image and circle the exact part. Thanks IMG_8194.jpeg
2WheelWillie
Lancaster, Pa
Looks like the motor mount to me, but I doubt it is leaking. Usually the are made or hard rubber. Ford calls them:
Insulator Assy - Engine Support Insulator
Picture is disorienting. Is that on the driver side? Looks like oil is leaking from the sensor or oil filter adapter and blowing back as you drive down the road.
Hamfisted
Ft Lauderdale
Yeah looks like it's just coming from the oil filter and running back. Clean the area off with some degreaser or carb cleaner spray and make sure your oil filter is snug and recheck it in a week or so to see if you can isolate the cause of the leak. Are you using a Motorcraft 820 filter ?
C
cozyjhoan
Arizona
Yes that is the driver side. I was thinking it was leaking at the oil filter adapter at first but that's where i saw the leak coming from so i just assumed it was from there. but I'll clean it and double check. Thank you.
C
cozyjhoan
Arizona
Yeah looks like it's just coming from the oil filter and running back. Clean the area off with some degreaser or carb cleaner spray and make sure you oil filter is snug and recheck it in a week or so to see if you can isolate the cause of the leak. Are you using a Motorcraft 820 filter ?
Yes i am currently using a Motorcraft 820 filter. I have a feeling It is coming from the filter i just wasn't sure since all the oil is dripping from that part and not the actual oil filter itself. I will clean it off and check to be positive and tighten it a bit more if i have to. Thank you
Broncoholic
Space Coast, FL
2003 2004 engine mounts are liquid filled - hydraulic engine mounts. It could very well be the mount leaking. My tire shop told me mine were leaking years ago. I thought it was BS until I looked them up. FWIW, I still haven't replaced my mounts.
proftomda
georgia
The gasket between the oil filter housing and the engine block is a known leak point.
gnorman
