Rear AC blend door actuator issue
kimblef63
Louisiana
Hi. I’m new to this so bear with me. I have a 2013 Expedition Limited. I replaced the rear air blend door actuator because it was clicking. While installing the new one the screw positions didn’t line up correctly so I plugged it in, adjusted the temp setting to move actuator to allow for screws to be installed. Once I did that I pressed the temp control from cold to hot on the dash control which caused the new actuator to fail again. I noticed that the control on the dash stays in auto mode and nothing I do will make it return to manual. I was wondering if that could have something to do with the actuator not functioning properly.
K
kimblef63
Louisiana
What I was wondering was is it possible that the climate control module is faulty causing the actuator to not function correctly or is there a process of calibration or reset to put the new actuator in the correct position.
JamaicaJoe
Oviedo FL
Did you ever get that figured out??
