G
Guest
Guest
OK the dealer has it back for the 6th time now.
01 5.4 4R100 4x4, 45K. Bought it used in Feb.
On a WOT 1-2 shift it "shudders." Almost like a rumble strip. Frequently on hilly high-speed roads it will do the rumble strip thing 3-4.
Dealer sent it out to a tranny shop... There 2 days now. Possibly a bad TC lockup solenoid.
I found the exhaust hanging a bit low and has excessive motion when kicked. The forward clamp was replaced but the pipes are FUBAR at the joint from it wobbling around. It will make a similar noise heard in the cab when the tailpipe is kicked.
Anybody else run across this one? What was it?
NVH diagnosis can run you around and they're not too well versed at the dealer I bought it from... And looks like I'm the primary diagnostician here...
