2020 AC Not Blowing Cold
ERNursebev72
Washington
Hello There!
About a week ago, the battery died. I had it charged back up and it started fine. But now the AC is not blowing cold. It was working perfectly fine prior to that - blowing cold and hard air.
Issue:
Blowing and hearing compressor click. No cold air. Also a increase/decrease in fan speed on deceleration/acceleration.
Things checked:
Reset the BMS
Reset the SYNC system
Pulled out Fuse 32 that belongs to AC Clutch - intact
I am looking at the fuse diagram and don't see anything else that is obvious that could be AC.
I am a nurse so I can help bring people back to life, but I am also a woman. I prefer to try to figure these things out on my own before taking it to a mechanic and spending more than I need to.
It has 60K miles no previous issues.
Engine 3.5L GTDI
Ideas?
99WhiteC5Coupe
Hello There!
Issue:
Things checked:
Reset the BMS
Engine 3.5L GTDI
Ideas?
I’d bet you have a bad battery and/or loose or corroded battery terminals and connectors.
E
ERNursebev72
Washington
It died because it got drained from a secondary battery onboard that runs a refrigerator that gets charged when running my vehicle from the alternator. I was supposed to turn it off when I parked for a week and forgot. So once the onboard battery died - it started running off the car battery and depleted it. Once it was jumped off, they are both working fine. The ford battery is only 6 months old and was purchased new.
E
ERNursebev72
Washington
If the battery is cranking now and the blower and compressor are running fine - how can the battery be the problem? Just trying to link it all together.
VCFP153
Hastings, FL
Hello There!
Issue:
Things checked:
Reset the BMS
Engine 3.5L GTDI
Ideas?
Interior temp sensor?
99WhiteC5Coupe
I have seen many batteries damaged from being discharged fully, then jump started and / or charged.
Years ago, batteries lasted a long time and could be repeatedly discharged and recharged, and keep going. No longer.
You may have a damaged cell that is causing intermittent electrical issues. New vehicles (loaded with sensors, computers, modules, etc.) are very sensitive to battery issues.
I wish you luck. Keep us updated on what you determine.
