stamp11127
Does your meter have a continuity setting? If you don't know, which make/model is it?
Current Issues:
No Crank No Start - key in start position causes click in trailer-tow relay.
No communication to PCM from OBD2.
No power to fuel pump unless relay bypassed.
Gear selector won’t release when key on/brake pressed.
Instrument cluster will not illuminate.
Turn signals not working - flashers DO work.
HVAC panel has no power.
Continuity setting is the first yellow one to the right of 200 ohms resistance.
Be careful with that meter "10A max unfused" means it burns/explodes if overloaded.
Switch disconnected. Testing input/output at the switch:
pin 4 to 7 in start
pin 4 to 6 in accessory and run
pin 4 to 1 in run and start
Each test should tone when the circuit path is good. Any that fails means a bad switch.
I am on the East edge!Where in Memphis are you? I'm on west edge of Gtown.
