Retiredusps
Just make sure who works on it flushes the system. Or you will have the same problem later on
accumulator/drier and expansion valve.Need to replace the filter/drier and the orfice. Then pull good vacuum and charge to factory specs.
Expansion valve not necessary unless it's not working. In that case compressor would work but no cooling effect. Should see some freezing up of liquid line.accumulator/drier and expansion valve.
It was just a correction since he called it an orifice. I know they aren't as critical as the old orifice.Expansion valve not necessary unless it's not working. In that case compressor would work but no cooling effect. Should see some freezing up of liquid line.
