Battery issue
TJ Toronto
Toronto
Hello
I recently had an issue with the battery draining after being parked for anything more than 1 day. I brought it to the mechanic, who said they checked everything and it was just the battery. So it was replaced about 3 weeks ago. It has been parked for the last 7 days and today when I went to go out, it was dead again. Not even doing the ticking noise as it often does when a battery needs a boost.
I boosted it and it started. I drove it back to the mechanic, who seemed shocked to see me, and explained why I was there. I decided to turn it off at the shop so he could see. Again, I had to boost it when I left. He says he’s going to check the alternator. Also! I should mention, this time as well, as soon as I boost it, the passenger side headlight burns out. This has happened about 3 or 4 times now. The bulb that burnt out today is about 4 weeks old. I’m beginning to get really frustrated and am considering burning the truck to the ground.
BigOleFordFan
PA
Sounds like a phantom ground and/or a short somewhere....
After getting a known good battery, start at the battery cables & clamps, which could be causing either or both of these issues, then work your way down the line to the various places that could have the above...
The headlight burning out after boosting could be from a power surge too, but that would warrant an alternator & voltage regulator test, as well as the headlight switch itself...
Just some suggestions to think about, I'm not an expert at this, I am merely passing along my general knowledge of & experience with how cars work :D
99WhiteC5Coupe
Hello
I had the right low beam headlamp built burn out several times, several weeks apart. I was buying high-quality bulbs.
The last time I changed it, I noticed the lamp socket was slightly burned. I tried to clean it, then used silicone dielectric grease on the bulb contacts and the lamp socket.
I bought the vehicle new and it has never been damaged or wrecked. The lamp assemblies are the original. 2015 Expedition Limited 4x4.
So far, the cleaning and dielectric grease has prevented the last new bulb form burning out.
You may want to remove the bulb socket and look at it closely with a flashlight, or in bright sunlight.
TXResponder
Turn on your headlights and check if your headlights flicker a little bit when cranking to start the truck. If so, that's one of the signs it's the alternator.
Also check that your battery voltage is ~13.9-14.1 with the truck on (and all the electronics off) after a short highway drive. If it's not, it's probably the alternator again.
It sounds like it's not charging the battery while you're driving, leading to the battery getting depleted.
