I wish more people cared about that. I live in the country so when blinding me it's really bad.so I'm don't think I'm bothering anyone anymore.
I know you bought bulbs but I use a variety of brands (AUXITO #1, JKCOVER #2 {they are going out of business so buy while you can}, ZDATT #3 {benefit of color filters}) Those are the three I go with and they work fantastically and none of them interfere with the radio or anything. Just a suggestion for youI got my 2015 XLT in June. The halogens were dim and I was often seeing my Trucks shadow in front of me when I was backlit by some car with LED lights following behind me. I decided to get some LED bulbs myself and spend the $150 on the Diode Dynamics SL-1 Bulbs. The installed easily and worked right out of the game (once you figured out the polarity).
So I've had these installed for about a month and while they are working great, I have a problem. I'm blinding everyone on the road. Popping the head light Assembly in and out is so easy its trivial. But I see that my 'aim' is just a bit too high and to the left (in other words right into the eyes of oncoming drivers). Also when following behind other cars, I fully light up their interiors. I often see people grab for the 'night' switch on their review mirrors as I roll up on them.
I have gone from being very pleased with my night illumination to self-conscious and guilty. I now hang back further from other cars and pretty much have several oncoming cars 'flash' me. I know for each one that does, that most others are also cursing my lights.
One of my main problem is that my lights are noticeably projecting high. Much higher than they need to be. Not sure if it was always that way with Halogens and were just too dim to be an issue, or if my removal and reinstall of the headlamp assembly knocked everything out of calibration, or if the LED bulbs just changed the aim.
So last night I decided to try to aim these things lower. I see an adjustment screw on the back of the assembly, so I put a phillips in there and turn. I had pulled up to the garage door and as I turned the aim of the lamp didn't change. It really didn't seem to change much or at all. I drove the truck around the block and noticed that the aim was no even higher! So at least I know it can change. I returned adjusted some more and tried to push the assembly in more at the bottom. I was able to get the focus to lower some, but it is really at where I started.
My question is how to I effectly aim this headlamp assembly? That screw adjuster really doesn't seem to steer the main bulb, or reflector, so I'm not sure what I doing when I use that. Any tips would be helpful.
Don
