Hello Forum! Wondering if anyone had seen this Electronic Limited Slip Differential Temporarily Disabled message before. (see image) My 2020 Platinum Max started doing this last week. The message randomly comes and goes, no buttons getting pressed on the dash. Why does this happen? Is this a safety issue? Thanks for your help!
Do you have the simulated lock button pressed? Do you have a spare tire on the rear? Been doing a lot of burnouts?
Like was said above, could be a sign you have an issue with a Wheel speed/ABS Sensor. If it is having an issue, the ELSD will turn off, because the computer cannot sense wheel speed differential correctly.
Have you scanned for codes?
Also, do a search on here, there have been several threads on this issue in the past with some good info, and history.
