engine lift points
B
bedrck46
Guest
guess you figure we are all mind readers How about some info about which engine you are going to lift telling year and model and engine would be nice information for you to share
tonydiv
technical advisor
Middle River, MD
Once you remove some of the front accessories and upper intake, there will be plenty of suitable lifting points to bolt mounts to.
One of the only place that would be off limits would be the exhaust studs. They are way too thin and fragile.
BrandonB
Kansas
On the 4.6 - at least on a 99 the front mount point is where the alternator bracket connects to. I'm guessing after removing the intake you can get to a spot on the back
Jaymoney
