WCoverdale
hey guys,
So I have an '07 that is having a weird issue and im hearing a lot of different answers and I figured I'd get your thoughts.
So the fan control speeds/off won't work. Whenever I try to turn off the climate control it kicks the fans onto max and doesn't turn off. If I have off selected and cycle the ignition it stays off.
The fan speed also doesn't work when I select what vent I want the air to pass through. But the vent selector does work.
The temperature select works and will adjust the fan speed to keep the temp at what I select.
I've heard blower motor module, climate control module, and blower motor resistor. Which do you guys think it is? Or do you have any different ideas?
Thanks!
Thanks!
