I did think of one other question, with the Timberline obviously I have the regular tail lights, not LED. I replaced the reverse lights with some bright LEDs, and I would like to do the turn/brake bulbs but I'm not sure if there is a preferred one that looks good in these housings, and won't cause any computer issues.
I'm not sure about the 22's, but in most older models (like my 011 EL), you have to either A) get LED's that have a built-in resistor, or B) get the resistors separately & splice them in, or your turn signals will start flashing about 10x faster than the original bulbs do, most commonly referred to as "hyperflash"...
The built-in ones cost a little more $$, but are a 1 & done install, whereas the LED's with out them will cost less, but require the purchase of the resistors (about $8-10 for a set) as well as the 2nd step of splicing the wires....
Choose wisely you must, because with this issue, help you the force cannot, hehehe...j/k
