The Wiped Cam
Well, ladies and gentlemen--it appears that the 2011 and up memory-optioned Expys are possibly pre-wired for a lot of things you can get in the same MY fully-loaded Expedition. Attached is the memory address, and the corresponding values, that let your memory-optioned 2011 Expy give you access to power folding (might work for other 5.4 Expys, more on this uncertainty later in the post)
My XLT-P w/ memory is pre-wired from the factory for power folding and driver-side auto-dimming functions. I should also inform you guys that 2011 is the ONLY MY Expy that came with a full size driver-side auto-dimming mirror AKA zero glare due to the absence of a blind spot mirror up in the corner. These rare auto dimming driver-side mirrors can be ripped out of any 2011 KR or Limited. Rest assured that any other auto-dimming driver-side mirror from a 3rd gen will work just fine, because I'm using 2013 mirrors in my 2011.
I tried to probe my IDS girl for the info regarding DSM address and values on 2011 and other MYs, but she politely refused to divulge that info to me (basically wanted to get paid for doing it herself). I then used the diff command on my linux pc to quickly figure out what the DSM in a 2011 KR or a Limited had that my 2011 XLT-P didn't. The attachment shows the line, in Motorcraft As Built format, that turned out to be different. I couldn't perform the same function on higher model year Expys because the modules in those .ab files look waaay different from my 2011. I do have access to a 2014 XLT-P also, therefore, I might be able to experiment with the memory addresses in the coming months.
I'm not attaching any pics of my install, since it's the easiest possible job on a memory-optioned Expy. 100% plug and play, so there's nothing to learn from install pics.
