I probably walked in on the mixed up middle of this so. If the question is, for a vehicle equipped from the factory with power fold mirrors, how do you fold them? Using the mirror adjustment switch on the drivers door, (3 position rotary), turn to center position, and pull switch straight back, mirrors will fold in. In center position pull switch straight back mirrors will fold out. Center position of rotary mirror adjustment switch controls the power fold feature. WARNING! If you are trying to get the mirrors to fold in, and out, with the ignition, IE; ignition off - Mirrors fold in. Ignition on - mirrors fold out, yes you can set that up in FORScan. BUT HERE IS WHY YOU MAY WANT TO THINK ABOUT IT! AND PROBABLY WHY FORD DOES NOT HAVE THE SYSTEM DO THIS (program it in), at/from the factory. The system is robust enough to handle folding the mirrors WHEN NEEDED. But not every time you park. The bulk of the system relays on plastic parts, gears, mechanisms, etc. The system is not water tight. Ford's Kentucky truck plant builds them but does not know the final destination for each vehicle. Could be Miami, FL, or Anchorage, AK, it's pot luck where they wind up as far as Ford is concerned. And there is good reason plastic is used instead of metal, plastic fails easier! Simply put you will be glad they don't automatically fold in sub zero temps where it rains, snows, etc. They will try, try, try, try, snap, and $$$$$$ to get fixed. Get too close to the curb, and that pedestrian, texting on their cellphone, about to step into the hearafter when you hit them. Will be glad only the mirror hit them, broke away, folded in, retracted, forcefully, (there will be functional damage), and a nasty bruise is all their arm has! Ever wonder why vehicle's no longer have pop up, or retractable headlamps like Corvettes used to?! Oblivious Pedestrians! And NHTSA, DOT, NIIHS, NTSB! And most of all, STUPID HUMANS! So no! Ford is not being cheap, cheeky, slick, loose, or fast with their use of plastic gears, mechanisms, parts in the power fold mirrors. They are between a rock and a hard place, only trying to protect US from OURSELVES, because an acronym said plastic is a, "Better Idea!"
Sent from my SM-G950U1 using Tapatalk
