I have a 2010 and it has a 8inch factory sub in the panel on the drivers side rear. The 2011 is the same, do you have sync and rear dvd? if so you have the same set up.You will see the grill in that panel, its square. There is room for a 10inch small inclosure of about a 1 cubic foot or less. I took out the factory sub and made a mold from fiberglass. The enclosure was about 1 cubic foot and I only need .45 for a high power 8inch so I had enough room for my amps too. I used alpine pdx for ther size. 600 watts to the sub and 150 x 4 to the front and rears. I went with the 8 because I did not feel like cutting a new grill into that panel. I used the rockford 360.2 interface so my factory head unit with all the sync and rear dvd all work the same as before. The factory system sucked so I could not help but upgrade it, but I wanted to keep the head unit the same. If you have the EL JL audio makes a box that will fit behind the panel. It has a 10 in it , but no room for the amps. There is not much room under any of the seats because they fold flat when you put them down. I looked under the 2nd row and that was the case. No chance on the third row either. It can be done....Pop the tray and cup holder out of that panel and you will see the sub, or if you don't have one there will be a whole lot of room there. Good luck..
