2018 expedition went crazy
Z
zain77
Iraq
Is the bad fuel still in it? Or did you drive it enough to get a few new tanks? Is the Check Engine Light on? If bad gas is still in it siphon it out and get good fuel in it. Take it slow and easy until the you know th ebad fuel is gone.
Almost all that bad gas has been gone. I believe it is totally consumed. I did refill it with a super gas, also I used a liqui Moly fuel system cleaner. No changes it keeps giving the same faults.
Mlarv
Eastern TN
Is your Check engine light on? I would run it for two tanks of super before I started replacing anything. Then I would start at the Cats.
Z
zain77
Iraq
Yes, engine light is on, I'm afraid, if i run it at all these faults a worst could be happen. So, what do you think?
Mlarv
Eastern TN
Your call on driving it. I would take it easy for at least two tanks of super to see if it starts to clear up. I see you can read the errors, can you clear them also? If so I would clear all DTC's and see which ones come back.
Z
zain77
Iraq
Thank you man for the advice. Yes, I can delete faults, and that is what I did one time but that was right away after all these come up. Unfortunately, they come back again all to gather. I may go with easy driving to see what happens!! My big concern is about the cam phaser, would the driving become harmful to the engine while that fault exists??
Mlarv
Eastern TN
I am not sure about the cam phaser faults causing issues if you keep driving. If the engine knocks (rattles) I would worry about it more.
Z
zain77
Iraq
I will double check the converters and see what's going on.
Jefes_Shyt
