305/70R18 Stock Timberline
Mack444
CA
Has anyone put this size on a stock Timberline? That’s the size I want to land with when I need a new set and am ok to trim a little if necessary. Thanks for any feedback! I’ve searched here a little but only seen 295 width maximum so far.
ak49
Alaska
From what I've heard from @LazSlate , 305/75R17s fit just fine. The 70R18s are slightly shorter too (depending on the manufacturer). But, I'm not sure about the width and offset of the rims which will be a factor. I'm running 295/70R18s on stock Timberline rims with a ReadyLift 1.5" front and 2" rear lift. This setup required slight trimming of the rear liner since the tire moved forward as a result of the lift. The front liner is probably 1/4" from requiring trimming.
Mack444
Mack444
CA
Wondering @LazSlate what wheels and specifically offset of said wheels on your setup? Stock being +39mm, anything between that and +34mm should be close to difference between your 305 and @ak49 295 in stock for width on interior well with anything greater than stock clearing me to the outer well/trim.
