AC plumbing Drawing for 2001 Expedition
JamaicaJoe
JamaicaJoe
Oviedo FL
Removed every piece I could get off because overspray was inevitable. Except for the roof rack, tow bar and emblems, it was faded black plastic of some type. The paint job was $1800 including tax and I spent another $1000 on supplies and a few pieces.
Wow, that is a great price. I should send mine up your way. I am trying to figure out how to remove the door guards. I really don't want them back on as the plastic "chrome" inserts are awful.
jr1under
Aiken, SC
Are you talking about the pieces in the picture? If so, I wonder if the chrome insert is just a decal you could remove with a heat gun.
JamaicaJoe
JamaicaJoe
Oviedo FL
It is some sort of reflective tape. I tried pulling it out and it is on there pretty good. Have not tried a heat gun. I would prefer pulling the whole guard off if I can figure out how. I hope it isn't glued on.
jr1under
Aiken, SC
I've never removed my door guards so this is just speculation but I venture they're attached the same way as the insignias, with alignment pins/holes and mounting tape.
jr1under
Aiken, SC
I think the lawn sprinkers worked on the Rad Support.
I remembered this comment when you mentioned something in another thread about electrolysis. Could the sprinklers be a thing? I lived in SE Florida for about 20 years and remember how sketchy the water quality was. Last house we had there was on well water and needed sand, salt and sulphur filters.
JamaicaJoe
JamaicaJoe
Oviedo FL
The local city water is corrosive to copper pipes. Every house built in this town with copper pipes has had to have a repipe with PEX. I would blame salinity. As far as the RAD support, the front of the car has been exposed to the sprinklers and washed on a weekly basis from them. But I can't rule out the aluminum radiator. After the Rad support is replaced, I intend to look into the voltage differential between both.
jr1under
Aiken, SC
Right now, I'm repainting my radiator grille from pewter to black and have the deflector, lights, etc. removed. If there's anything in that area you'd like to see, let me know.
JamaicaJoe
JamaicaJoe
Oviedo FL
If its not too much trouble I would like to see the radiator support area behind the grill/fascia from corner to corner. I am curious how much stuff is hanging onto that support. Also the grill as removed. I am planning to repaint mine as well and wonder how it is fastened.
jr1under
Aiken, SC
It's too humid today to finish painting so I can take more pictures.
jr1under
Aiken, SC
Attaching the grille is a piece of cake; removing it is 16 chances to break off a plastic tab. I used a heat gun to soften it up a little. Painting is also a pita because you have to hit it from so many different angles.
Jefes_Shyt
