Heavymech64
Seeing that I have not come across a similar problem in the forums on the 3rd gen expedition. I wanted to post it here and get any ideas from the members. Last week my driver side door lock quite working, then worked once or twice randomly then died. I immediately thought actuator. Bought OEM and replaced. Still nothing. Tested power to the switch. 10V. OK. Tested continuity of the switch between the points. OK. Tested power at the actuator. Nothing. Checked it back to the main connector block in the door. Nothing. Checked the harness at the door hinge. No visible issues. After many hours of frustration with no resources to look at, I traced the wiring to the fuse box in the passenger side footwell. The book labels a fuse for lock/unlock relay. Checked the fuse. OK. Pulled the fuse and the locks still seem to operate... not sure whats going on here. Put the fuse back and next locate these refrenced relays. Audible checks lead me back to that fuse box. Relays are clicking inside. Pulled it and split the box. Nothing but circuit boards inside... now if I was an electronics guru I would pull it apart further and solder in a new relay. My only guess at this point is the contacts for the Driver side door circuit are fried and I now need to replace the whole fuse box assembly. I will price one out through Ford and also see if a wrecker has a 3rd gen that may work. Any further suggestions?
2017 Ford Expedition Limited EL
