HELP!!! 05 5.4 oil pump???
BrandonH13
Osawatomie, Kansas
So we just bought a 2005 expedition with the 5.4 in it. We have had it about a month and a half...second vehicle so its rarely driven. Before we bought it the dealership had the timing chains, guides, arms, cam sensors replaced because it was making a noise.
Well about 2 weeks ago my wife says it died on her when she was backing up. Restarted it just fine and didn't have a problem with it. Then I drive it to work (which is 90% highway) When I start to stop at a light it just dies, shift into neutral and restart it....now its making a loud clacking sound and have to keep some gas on it so the rpms stay up. Check engine light now comes on, so I get it to work and check the codes...
P0345 - camshaft position sensor bank a circuit, bank 2
P0340 - camshaft position sensor circuit malfunction
So in my mind I am thinking its the timing stuff they just did or its the cam phasers. It will be fine when its cold and after it warms up is when you hear the clacking and the truck wanting to die. We test drove a F150 that did the same exact thing and since we were getting the 5.4 I tried to research before hand about the bad things.
So I call the dealership we just bought it from and they said it was serviced at this place and it has a 12 month 12,000 mile warranty for the timing parts. So I call the place and after about 2 weeks FINALLY get someone to call me back. We take it there and tell them to check whatever they need under their warranty but to call before they do anything else. They are like oh its probably just the connections so we will lube them up and see what happens. Well after a couple days I call and get "well it wasn't that so we are tearing into the engine to see if its the timing stuff we did". Couple days later again I call and get "well the tensioners were bad and thats the only thing we didn't replace" this is a thursday so the owner which I have been talking to tells me he wants to drive it 20-30 miles to make sure the noise isnt going to come back. Well AGAIN a couple days later I call on a tuesday for him to tell me he has taken it to the local ford shop because it still has the noise. Well he ends up calling me friday afternoon to say that ford said "its the oil pump so you need a new engine"
Sorry for the story, but my question is would the oil pump just go out like that and have the syptoms of the cam phaser or do you think it sounds like cam phasers? I never remember the oil pressure dropping or the dummy light coming on the dash, which I would think would happen if it was the oil pump.
ANY help would be great since its passed the 30 days and I really dont want to fork over another $5K for a new engine if I dont have to
sgtowing
Supporting Members
Valrico, Fl
Not sure if this helps but mine starts to run rough when its low on oil. Its never made any noise and the the gauge showed good pressure even when it was low on oil.
You might want to spend your own money and take it another ford dealer that has never seen the vehicle and see what they say. :shrug:
Sent from my DROID BIONIC using Tapatalk
B
BrandonH13
Osawatomie, Kansas
Yeah I am going to call the ford dealership today when I get a chance and ask how they figured it was the oil pump or what steps they took to get there.
Where is the oil pump located on the expedition anyways? It is in the oil pan or external?
B
BrandonH13
Osawatomie, Kansas
Well I called the local ford dealer and they sent me the inspection sheet.
The concern was - engine warms up , engine rattles and stalls, cam phasers are new.
The correction - Inspect, bank 1 not timed correctly. Also has low oil pressure causing the cam phasers to not operate properly.
If it wasn't timid right, would that make a difference on the oil pressure? Funny how they "fixed" one thing and now the codes that I got have nothing to do with timing...so they messed it back up when they "fixed" the tensioners
B
BrandonH13
Osawatomie, Kansas
Talked to the tech yesterday. He said he has been the engine guy for 14 years and actually had 2 other trucks up there for the same problem the day he had mine. He said he hooked it up to the IDF or whatever computer and when we started it up, he could tell it wasnt timed right.
He said when it started to rattle, they call it the death rattle because there is pretty much nothing you can do when it gets that bad. He said that it could be the oil pump, but also when this engines get "higher" mileage on them then the heads can start to bleed off the oil. He said we could change heads, but that might not fix the problem or that he has heard of people putting heavier weight oil in them and it "helping" but not fix the problem. He said that since it doesnt have a minimum of 25 psi oil pressure, then the phasers won't work like they are suppose to.
He also said that all the timing stuff they did was also probably just a "band-aid" and wasn't the real problem to begin with.
khpony
SW Colorado
Did you buy it from an individual or a dealer? If it was a dealer I think I'd make a run at having the dealership repair it at their cost.
sgtowing
Supporting Members
Valrico, Fl
Like I said Brandon, prepare for a lawsuit. Also, if the dealer wont fix it, run a straight 40 or 50 weight oil to help the pressure and get as many miles out of the engine as you can. It's close to summer so the cold shouldn't be to bad much longer so startups wont be as bad with a thicker oil.
B
BrandonH13
Osawatomie, Kansas
It was a small dealer and they said since we didn't "notify" them and took it straight to the place that did all the timing stuff for them that we are "out" of their 30 day warranty. Pretty much going to have to get a lawyer, file complaints and other things to try and get them to help out.
After I have been trying to research, I hope its just debrie has gotten in the oil pan from when they changed everything out. Also I have been researching and found out that the vct's might be clogged or the lash adjuster, roller rockers might be going bad, which would make the heads bleed off pressure like the tech at ford said I would think right?
We just might take it home, have my cousin that is a diesel mechanic come over and take off the valve covers and see if we can find anything. Maybe run some seafoam through it and drop the oil pan. The wife wants to just get rid of it at this point somehow and I am starting to not blame her which is sad
B
BrandonH13
Osawatomie, Kansas
Sorry guess I should go more into it...
Talked to the place that did the timing and he said when they got it, it was opposite and it would rattle when it was cold and would smooth out when warm. So they opened it up to replace the phasers and noticed one of the guides was broke, which was letting the chain slap. Replaced all that and said they cleaned up the valve body and the vct sensors still had the screens so they didnt mess with them or worry about cleaning them. Drove it some and it ran fine.
So now I am wondering if since the guide was broken, if some pieces got down to the oil pan and now are trying to get sucked up and stuck on the pick up screen. He said that he put a manual oil pressure gauge on it and it was going crazy, but didnt ever drop below 12psi pressure.
Richard Lewis
Saint Clair Shores, Michigan
Did you get it taken care of yet i have the same truck and just finished doing all the things the machenic said he did my truck runs like it just pulled up out of the lot i bet they didnt drop the oil pan and there is debri in there also i would just change out the vct selonoid if it has over 80000 on it both sides also could be losing pressure from the timing chain tensioner if they broke the seal when installing them it will lose alot of oil pressure never put heavy oil in it only 5w20 and only use motorcraft oil filter the others use a cardboard type of filter it gets into the oil passages and clogges them if you need any help let me know ive had my engine apart many times its a great engine and has lots of power just make sure the people working on it know what there doing if that machenic told you to put heavy weight oil in there that tells me he know nothing about this 5.4 modular engine
sharprd65
