Remote start - last problem to solve
gural
Poland / Europe
Dear All
First i checked the forum but still its unclear for me
Ford Exp XLT 2019
I bought the perimeter plus (JS7Z19A361A)
I inslated it in the car
Via Forscan i found the options reomte start (it was in polish) but never the less i putted it on enable in BCM and in IPC
after that in instrumental cluster in dash i have option for remote start (i click it yes and auto)
according to Youtube it should work as configuration of buttons on key fob close open close
but nothing happens
should i buy a key with 5 buttons (meaning with remote start -> My existing key is HS7T15K601AC with 4 buttons) or I should change someting else extra
maybe i should disconnet the perimeter and plug it once again??
Mr Big
Tampa Bay, Florida USA
Dear All
Ford Exp XLT 2019
but nothing happens
I can't speak for what exact FOB to get, but my FOB button process for remote start is press lock then the start 2x button 2 times.
This is what my FOB looks like.
G
gural
Poland / Europe
so i got 2 questions - is there a option to start car with my 4 button key
currently my oryginal key have - JL1T 15K601 AC
If not - which number will fit
I see a lot of keys with diffrent end - question is if thay will fit...
Mr Big
My remotes, for my 2019 Platinum are that model number. I would assume they would be the same for the XLT, unless you used an after-market remote start.
You would have to get the key cut or hopefully your old one fits.
G
gural
Poland / Europe
omg
i was watching again the next youtube films
and on on of then a gay had same problem
it came that to the perimiter there is added a small platics thing like in the att (its a bypass)
so i went to check the pachage -> becouse its a Europe it must go via 2 custmos -> so my package is in 3 carton...
and in one of them there was this thing
i plug it and it works
So to sum up
In 2018 + in XLt you need to buy permimeters plus and plug it + in the package there is a bypass
via forscan in BCM and IPC change options to remote start - enable
in the dash you get option remote start and make your own configuration
then to make the procedure you do - close open close - car starts
same procedure to stop
thanks for all
