These instructions are for installing and removing the CD changer in a 2000 Expedition. It should be the same 97-02 Expeditions, though there's no guarantees.
As always, I'm not responsible if you break anything.
1. Disconnect the battery ground cable.
2. Remove the mat at bottom the of the console bin and remove the screws.
-To ease removal of the trim panel, pull the front edge back and lift out.
3. Remove the screws and pull out the CD changer and bracket.
4. Disconnect the electrical connector.
5. Remove the screws.
6. To install, reverse the removal procedure.
