u2013 the compass module is not responding
erickperez
Panama,Central America
Yesterday I had the car interior cleaned profesionaly. Today the engine light turned on and I got this code u2013 the compass module is not responding.
Then it goes crazy beeping.
Any ideas about how to fix that? or what fuse in the fuse box relates to the compass so at least I can turn it off while figuring out if vapor form the cleaning went inside some wiring?
Thanks in advance.
Ford Expedition 2005 EB 5.4L 3V
whtbronco
Winchester, VA
I'm pretty sure the compass is the little box that hangs off the rear view mirror, if I recall correctly. Check to make sure the connector didn't pop loose. I don't think you can pull that fuse and still drive the truck due to the brake shift interlock.
Here's the fuse info for the compass, right side of the fuse box near the center:
Goff69
