Rear End Failure
jddotson
Stewartsville
I finally got my 2019 back and so far so good. Rear differential was removed and disassembled for inspection (no issues found) and reinstalled. Ford then replaced the HCU and it seems to have fixed the binding problem. Hopefully this resolves the issue.
nilfx
atlanta
I’m joining the club late here…. My 19 is doing the same thing. Does anyone have the invoice with a parts list of what was replaced? Looking online I think I could get away with just doing the carrier. I’m also thinking about grabbing a salvage one.. any thoughts?
kryichek
to bad you cant replace it with a simple LSD and get away from the electronic stuff
nilfx
atlanta
Just an update, I ended up purchasing a salvage one to swap in and keep my truck on the road. So far no noise, I did notice the HCU on top has been updated to a newer style. I plan on opening up my differential this week to see what’s damaged and if I can get away with just replacing the actuator.IMG_3462.jpeg
Mr Big
Tampa Bay, Florida USA
My 2019 makes a grind occasionally when I turn backing up. But it never does it if I turn off traction control. So there may be a connection there to my noise.
nilfx
atlanta
Hopefully it’s just a traction issue! The differential issue for me was in both directions when turning. I’m guessing I had the problem for a long time now because it feels like a different truck now that it’s so quiet.
dowen
Calgary
2020 Expedition Platinum w/towing package currently in for the 4th time on issue where there is binding in rear differential; initally thought it was transmission related even after having the transmission valve body replaced in February. Took in back in March, they couldn't replicate, got progressively worse over time, initally binding in the rear at low speeds when turning slightly going up hill, then at higher speeds with tighter radius (highway on/off ramp). Dealer diagnosed under TSB 24-2188, overhaulled transfer case; issue was still there when I picked up, take back for shop operations manager test drive, commits to put their best tech on it and then goes on holidays. Now back in and they have ordered parts for front differential.....don't appear to have even looked at rear differential. Symptoms can be immediatey triggered when drive selector is put in SAND mode. Mentioned HCU as possible problem from earlier posts on this thread and their eyes glaze over.
