Deadman
looks good, like to see the pics at night
Just look at the sun, basically the same pic...... Its 3-4X as bright as the headlights. I don't even waste my time with the hi beams most nights now.
Oh my god please don’t be one of those guys. In normal on road driving why would you ever need more than the incredible brights on this truck? And they turn on and off for you. People that drive around with light bars on should be beat!!!!Just look at the sun, basically the same pic...... Its 3-4X as bright as the headlights. I don't even waste my time with the hi beams most nights now.
I'm fully capable of dimming my lights, including this Lightbar. I don't rely on the idiot computer to auto dim my headlights either, that POS is a complete joke.
Different states must have different rules regarding the use of auxiliary lighting while on the road. The rules in PA state that off road lights need to be physically covered while on the road, but no one enforces it. If a cop catches someone in PA with their lightbar on while on the road, they'd likely get a warning or ticket.
067 Pa. Code § 175.66. Lighting and electrical systems.
https://www.pacode.com › secure › data › chapter175 › s175.66.html
(9) In accordance with 75 Pa.C.S. § 4303(f) (relating to general lighting requirements), roof or roll bar mounted off-road lights may be installed if they are not used on a highway or trafficway and are covered with an opaque covering at all times while operating on the highway or trafficway.
That looks great! I’ve been looking at the exact same setup for mine, and now that I know it will work, I’ll be ordering for sure. My biggest worry is breaking a hidden clip or something on the cheap plastic trying to disassemble the bumper! They now make one that has a DRL feature as well that might be interesting.
Deadman, couple of questions if you don't mind. Getting ready to install this lightbar on mine and was looking for some clarification.I didn't like the switch that came in that DRL harness, so I opted against it simply for my interior thoughts on switch placement.
I think I went above that sensor. I almost think I drilled a hole a bit lower and relocated that sensor.
I'm not worried about the airflow, as I live in Northern Wisconsin. I don't tow much with it as I have a 3/4 ton diesel for that. There is a ton of air openings even with this in there. I'm honestly not a bit worried. I'd be more worried about the day those stupid luvers FAIL and cook your engine because they won't open up.
I pulled the tires just to make my life easier. It was worth it. The bumper bolts are nearly not visible. I had to go by feel to find them. They are all the way on the outside and up. They are fairly close to each other. I pulled the tires to help locate the bolts initially.
