99 Expy
Sounds good!! Hope you are happy with all of the hours and hard work you put into making it an even greater machine
Hi tom truck looks great the big difference in the trannys are internal the regular 4r100 has a 3 pinion plantery and a 4 bolt converter and a lightning 4r100 has a 6 pinion plantery and a 6 bolt converter, also the shift points are different,where is the valve cvr leaking up frt by the timing cover if so there is flat spots where u shold've put a dab of silicone top and bottom of the valve cvr if u did do that they would leak. Looks good sounds real good too, one day i'll get my all done and put it up too see still working on getting the paint work done hard to doit yourself and work a full time job, but worth the time and effort hope this helps.Good Luck
