Front Blower not working...
01 Expo
Ohio
The other day my front blower just stopped working on my 01 Eddie Bauer while the rear blower continues to work. Does anybody know how to fix this?
ELVATO
Orlando, FL
Manual or EATC? Does it not work for all speeds and positions?
01 Expo
01 Expo
Ohio
I have checked fuses and it is the EATC and it doesn't work at all.
bigfry
California
I know this is a very old thread, but my '02 just started doing the same thing, and as I'm just starting research was wondering if a conclusion was ever made in this matter or similar.
Bedrck47
Elizebethtown, PA
check your fuses refer to your owners manual
do you have manual or EATC controls
could be the blower motor resistors/controller
Bedrck47
Elizebethtown, PA
The blower motor is inoperative — EATC
Circuitry short/open.
Blower motor relay.
A/C blower motor.
A/C blower motor speed control
bigfry
California
Well, as far as I can tell the fuses are good, and if I'm reading the manual right, the "Aux" blower is via the main fuse first, so if the rear is working then it shouldn't be the fuses? Anyway, I checked them and they're continuous - as well as the relay under the hood.
I have an EATC, and ran the diagnostic on it, but it of course came up clean. In the course of my research I have found quite a bit on manual controls, and not so much on EATC systems.
I took a couple quick pics hoping for some clarification. Is the first cylinder kinda looking black one the blower fan, and the second pic with the white connector towards the right the speed control?
I did stick a voltmeter across the two leads going into what I've taken to be the blower motor, and with the EATC off, it measured 8.68v, and with the EATC cranked to max it measured 11.77v.
Bedrck47
Elizebethtown, PA
your thought about
" the "Aux" blower is via the main fuse first, so if the rear is working then it shouldn't be the fuses?
both blower motors are on separate fuses.
ALWAYS check fuses with a meter or test light.
Since you are getting voltage at the blower which would be the red/white and brown/white wires it appears that the blower motor is bad.
You may want to disconnect the connector at the blower motor and check the motor with a OHM meter or you could hook up a set of jumpers and put 12 VOLTS directly to the motor
have attached prints for you
  • 55-01.pdf
  • 55-05.pdf
