gixer2000
Retrofit or Bust
Good stuff! Keep in mind I'm also from Massachusetts about 35 minutes from the sagamore bridge so if you ever need a hand let me knowI kicked them off.
Had a similar issue during VA state safety inspection. They came and got me from the waiting room, explained that my lug nuts were frozen and they couldn't get them off, and had busted two sockets on an impact wrench in the process. I was intrigued. So I asked if I could take a look; I picked up the impact wrench, held the socket in loosely in one hand and hit the trigger with the other.I'm guessing you're trying to remove the wheels too!
A few years ago I was having the tires rotated at a non-Ford shop and they couldn't get the wheels off either even after removing all five lug nuts from each wheel. Three or four guys were kicking my truck's wheels when I suggested they remove the 6th lug nut... (And these guys want to boost the minimum wage to $15...)
You problem may be as simple.
-- Chuck
You know what happened.
Yep, they were tightening my lug nuts, not removing them. So I zipped one of the nuts off to prove they were idiots, put it back on, then told them to get my truck off the lift and I left, with no further comment.
