Hello, my 2018 Expedition suddenly read the following codes, knowing that I changed the cam phaser last year. It is worth noting that I used the Expedition on a trip and had to use bad fuel because of the lack of improved fuel in that area, and then these faults appeared once. Is there any help in this case? I checked the fuse box and the VVT solenoids, and there was no problem.
Even I don't know where to start!!!!?
Any suggestions pls?
Sorry for my bad language.
Thanks in advance!
Car Scanner ELM OBD2
DTC report
Selected brand: Dodge
VIN: 1FMJU1JT1JEA49554
============1==============
P0010
Raw code: 0010
ECU: Engine control unit
Status: Confirmed
OBDII: Camshaft position (CMP) actuator, intake/left/front, bank 1 - circuit malfunction
============2==============
P0013
Raw code: 0013
Status: Confirmed
============3==============
P0020
Raw code: 0020
Status: Confirmed
OBDII: Camshaft position (CMP) actuator, intake/left/front, bank 2 - circuit malfunction
============4==============
P0023
Raw code: 0023
Status: Confirmed
OBDII: Camshaft position (CMP) actuator, exhaust/right/rear, bank 2 - circuit malfunction
============5==============
P0135
Raw code: 0135
Status: Confirmed
OBDII: Heated oxygen sensor (HO2S) 1, bank 1, heater control - circuit malfunction
============6==============
P0141
Raw code: 0141
Status: Confirmed
OBDII: Heated oxygen sensor (HO2S) 2, bank 1, heater control - circuit malfunction
============7==============
P0155
Raw code: 0155
Status: Confirmed
OBDII: Heated oxygen sensor (HO2S) 1, bank 2, heater control - circuit malfunction
============8==============
P0161
Raw code: 0161
Status: Confirmed
OBDII: Heated oxygen sensor (HO2S) 2, bank 2, heater control - circuit malfunction
============9==============
P0443
Raw code: 0443
Status: Confirmed
OBDII: Evaporative emission (EVAP) canister purge valve - circuit malfunction
============10==============
P0446
Raw code: 0446
Status: Confirmed
OBDII: Evaporative emission (EVAP) system, vent control - circuit malfunction
============11==============
P2418
Raw code: 2418
Status: Confirmed
OBDII: Evaporative emission (EVAP) switching valve - open circuit
============12==============
P0430
Raw code: 0430
ECU: Engine control unit[Archive (inactive)]
Status: Permanent
OBDII: Catalytic converter system, bank 2 - efficiency below threshold
============13==============
P0420
Raw code: 0420
Status: Permanent
OBDII: Catalytic converter system, bank 1 - efficiency below threshold
============14==============
P0010(00)
Raw code: 001000
Status: Test failed, Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear, Warning indicator requested
Thanks in advance!
DTC report
P0010
Raw code: 0010
Status: Confirmed
P0013
Raw code: 0013
Status: Confirmed
P0020
Raw code: 0020
Status: Confirmed
P0023
Raw code: 0023
Status: Confirmed
P0135
Raw code: 0135
Status: Confirmed
P0141
Raw code: 0141
Status: Confirmed
P0155
Raw code: 0155
Status: Confirmed
P0161
Raw code: 0161
Status: Confirmed
P0443
Raw code: 0443
Status: Confirmed
P0446
Raw code: 0446
Status: Confirmed
P2418
Raw code: 2418
Status: Confirmed
P0430
Raw code: 0430
Status: Permanent
P0420
Raw code: 0420
Status: Permanent
P0010(00)
Raw code: 001000
